이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
Remove the back foot from the hinge mount by gently pulling it upwards.
Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
Once the screws are removed, lift the back plate off of the display.
Completely remove the back plate and set it aside.
Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
