주요 콘텐츠로 건너뛰기
Apple EarPods Disassembly
필요한 것
  1. Apple EarPods Disassembly, Tools You Need: 1 단계, 이미지 1/2 Apple EarPods Disassembly, Tools You Need: 1 단계, 이미지 2/2
    • X-ACTO Knife
    • Tweezer
    • Triangle Paddle
    • Alcohol
    • Cotton Swabs
  2. Apple EarPods Disassembly, Opening Earpod: 2 단계, 이미지 1/2 Apple EarPods Disassembly, Opening Earpod: 2 단계, 이미지 2/2
    • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
  3. Apple EarPods Disassembly, Cleaning Inside and Out: 3 단계, 이미지 1/1
    • Soak one side of a cotton swab with alcohol
    • Clean inner and outer pod using swab soaked in alcohol
  4. Apple EarPods Disassembly, Cleaning the Speaker Cone: 4 단계, 이미지 1/1
    • Carefully clean the speaker cone using cotton swab
    • Once clean, reattach the earbud
  5. Apple EarPods Disassembly, Removing the Grill: 5 단계, 이미지 1/2 Apple EarPods Disassembly, Removing the Grill: 5 단계, 이미지 2/2
    • Carefully remove grill out of both earbuds using tweezers
    • Take precautions not to bend grill excessively
  6. Apple EarPods Disassembly, Grill Polishing: 6 단계, 이미지 1/1
    • Clean grill with cotton swab soaked in alcohol
    • Remove any build up of wax or sweat
  7. Apple EarPods Disassembly, Placing Grill Back: 7 단계, 이미지 1/2 Apple EarPods Disassembly, Placing Grill Back: 7 단계, 이미지 2/2
    • Once the grill is clean, place the grill back inside of the apple earbuds
결론
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
다른 7명이 해당 안내서를 완성하였습니다.
Eduardo Gonzalez
회원 가입일: 10/31/18
365 평판
안내서 1개 작성함
댓글 한 개
When I re assemble they won’t stay closed. Do I glue them back together?
Patrick Appleby - 답글
댓글 쓰기
조회 통계:
24 시간 전: 25
7일 전: 130
30일 전: 633
전체 시간: 40,885
