주요 콘텐츠로 건너뛰기
Apple Extended Keyboard A1243 Key Replacement
필요한 것
  1. Apple Extended Keyboard A1243 Key Replacement, Key: 1 단계, 이미지 1개 중 1개
    • Place the keyboard on a flat surface.
  2. Apple Extended Keyboard A1243 Key Replacement: 2 단계, 이미지 1개 중 1개
    • Inspect the key that is stuck or the key mechanism where the missing key was.
  3. Apple Extended Keyboard A1243 Key Replacement: 3 단계, 이미지 2개 중 1개 Apple Extended Keyboard A1243 Key Replacement: 3 단계, 이미지 2개 중 2개
    • If the key is stuck, gently insert a spudger under the edge of the keycap.
    • Start from one corner and carefully pry the keycap from the keyboard, working your way around it until it pops out.
    • Inspect the key mechanism (scissor switch under the keycap) for any damage or debris.
    • If the keycap is dirty, clean it by soaking it in warm soapy water.
    • Ensure the key mechanism and cap are dry before reassembling.
  4. Apple Extended Keyboard A1243 Key Replacement: 4 단계, 이미지 2개 중 1개 Apple Extended Keyboard A1243 Key Replacement: 4 단계, 이미지 2개 중 2개
    • If the mechanism is damaged, you will need to replace it.
    • Install the new or previously removed key by aligning the keycap with the key mechanism. Align the top of the scissor-switch to the metal notches on the keyboard and then align the bottom of the switch, ensuring you hook the scissor-switch onto the metal tab on the keyboard.
    • Press down firmly on the keycap until it snaps into place.
  5. Apple Extended Keyboard A1243 Key Replacement: 5 단계, 이미지 1개 중 1개
    • Test the key by plugging in or turning the keyboard on to see if it works correctly.
결승점
작성자
1다른 기여자 명과 함께
Laura Caucci
회원 가입일: 01/13/25
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 53
지난 30일: 276
전체 시간: 1,429
