주요 콘텐츠로 건너뛰기
Apple IIc Floppy Drive Replacement
필요한 것
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 1 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: 1 단계, 이미지 2개 중 2개
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Floppy Drive Replacement: 2 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Floppy Drive Replacement: 3 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Floppy Drive Replacement: 4 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the handle straight up to remove.
  5. Apple IIc Floppy Drive Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: 6 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement, Floppy Drive: 6 단계, 이미지 2개 중 2개
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  7. Apple IIc Floppy Drive Replacement: 7 단계, 이미지 3개 중 1개 Apple IIc Floppy Drive Replacement: 7 단계, 이미지 3개 중 2개 Apple IIc Floppy Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  8. Apple IIc Floppy Drive Replacement: 8 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
  9. Apple IIc Floppy Drive Replacement: 9 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully lift the floppy drive cage straight up to remove it.
  10. Apple IIc Floppy Drive Replacement: 10 단계, 이미지 2개 중 1개 Apple IIc Floppy Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the floppy drive straight up to remove.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alexandria Weinberg
회원 가입일: 10/06/11
601 평판
안내서 3개를 작성함
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 회원
CPSU-MANESS-F11S21G23
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 25
전체 시간: 5,917
