주요 콘텐츠로 건너뛰기
Apple IIc Speaker Replacement
필요한 것
  1. Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: 1 단계, 이미지 1/2 Apple IIc Speaker Replacement, Disassembling Apple IIc Cover: 1 단계, 이미지 2/2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Speaker Replacement: 2 단계, 이미지 1/2 Apple IIc Speaker Replacement: 2 단계, 이미지 2/2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Speaker Replacement: 3 단계, 이미지 1/2 Apple IIc Speaker Replacement: 3 단계, 이미지 2/2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Speaker Replacement: 4 단계, 이미지 1/2 Apple IIc Speaker Replacement: 4 단계, 이미지 2/2
    • Lift the handle straight up to remove.
  5. Apple IIc Speaker Replacement, Keyboard: 5 단계, 이미지 1/2 Apple IIc Speaker Replacement, Keyboard: 5 단계, 이미지 2/2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Apple IIc Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Unplug the speaker from the mother board by pulling horizontally.
  7. Apple IIc Speaker Replacement: 7 단계, 이미지 1/1
    • Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • An easy way to heat the glue is by using a hair dryer on a low setting.
    • When heating the glue, do not use any high wattage device! This may burn or damage the chips or circuit board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Josiah
회원 가입일: 10/06/11
658 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 회원
CPSU-MANESS-F11S21G23
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 1,572
