주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Apple Lisa 800K Floppy Drive Installation
필요한 것
  1. Apple Lisa 800K Floppy Drive Installation, Remove Card Cage: 1 단계, 이미지 1/2 Apple Lisa 800K Floppy Drive Installation, Remove Card Cage: 1 단계, 이미지 2/2
  2. Apple Lisa 800K Floppy Drive Installation, Remove the I/O Board: 2 단계, 이미지 1/2 Apple Lisa 800K Floppy Drive Installation, Remove the I/O Board: 2 단계, 이미지 2/2
    • Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
    • Release both clips holding the I/O Board.
    • Pull the I/O Board up to remove it.
  3. Apple Lisa 800K Floppy Drive Installation, Remove Floppy ROM: 3 단계, 이미지 1/1
    • Locate the chip labeled U2A at location 2A.
    • Remove the ROM chip with a chip removing tool of your choice.
  4. Apple Lisa 800K Floppy Drive Installation, Installing the 800K ROM: 4 단계, 이미지 1/1
    • Insert the 800K ROM in the empty socket from step 3.
  5. Apple Lisa 800K Floppy Drive Installation, Reassembly: 5 단계, 이미지 1/2 Apple Lisa 800K Floppy Drive Installation, Reassembly: 5 단계, 이미지 2/2
    • Reinstall the I/O Board.
    • Reinstall the Card Cage.
    • Reinstall the Lisa's rear panel.
  6. Apple Lisa 800K Floppy Drive Installation, Remove Front Panel: 6 단계, 이미지 1/2 Apple Lisa 800K Floppy Drive Installation, Remove Front Panel: 6 단계, 이미지 2/2
  7. Apple Lisa 800K Floppy Drive Installation, Remove the Drive Cage: 7 단계, 이미지 1/3 Apple Lisa 800K Floppy Drive Installation, Remove the Drive Cage: 7 단계, 이미지 2/3 Apple Lisa 800K Floppy Drive Installation, Remove the Drive Cage: 7 단계, 이미지 3/3
    • Twist the thumbscrew below the Drive Cage.
    • Slide Drive Cage out.
    • Unplug any attached cable.
    • Unscrew all the screws on the bottom of the Drive Cage to remove the floppy drive.
  8. Apple Lisa 800K Floppy Drive Installation, Installing 800K Floppy Drive: 9 단계, 이미지 1/1
    • Attach the 800K Floppy Drive to the 800K Drive Bracket. If you do not have an official 800K bracket then you can be create and fashion one yourself as displayed in the image.
    • Reattach all Drive Cage wires.
    • Slide Drive Cage back into the Lisa.
  9. Apple Lisa 800K Floppy Drive Installation, Reinstall the Lisa's Front Panel: 10 단계, 이미지 1/1
    • Reinstall the Lisa's Front Panel.
    • The 800K floppy drive will perform as a 400K drive if the 800K driver is not installed.
    • MacWorks XL 3.0 and below does not support 800K functionally. MacWorks Plus and MacWorks Plus II natively support 800K functionally automatically.
    • Lisa Office System 3.0 and newer supports 800K functionality with a driver.
    • The driver can be found here.
    • The 800K driver floppy supplies the driver installer utility.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
LisaGuide
회원 가입일: 12/30/18
1,833 평판
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 735
