주요 콘텐츠로 건너뛰기
Apple Lisa MacWorks II PFG Instalation
필요한 것
  1. Apple Lisa MacWorks II PFG Instalation, Disassembly: 1 단계, 이미지 2개 중 1개 Apple Lisa MacWorks II PFG Instalation, Disassembly: 1 단계, 이미지 2개 중 2개
  2. Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 2 단계, 이미지 2개 중 1개 Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: 2 단계, 이미지 2개 중 2개
    • Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
    • Release both clips holding the I/O Board.
    • Pull the I/O Board up to remove it.
  3. Apple Lisa MacWorks II PFG Instalation, Removing the 8530 Chip: 3 단계, 이미지 1개 중 1개
    • Remove the chip marked 8530 at location 9D.
  4. Apple Lisa MacWorks II PFG Instalation, Crystal Insulation: 4 단계, 이미지 1개 중 1개
    • Next to the chip removed in step 3 is a crystal. These are not always installed with a plastic coating. The crystal shown in the image is insulated.
    • If your crystal is not insulated then tape a small piece of cardboard on top of it.
  5. Apple Lisa MacWorks II PFG Instalation, Installing the Daughter Board: 5 단계, 이미지 1개 중 1개
    • Ensure the pins on the MW+II PFG (Programable Frequency Generator) are perfectly straight. If they are not then slightly bend them into place.
    • Insert the PFG into the 8530 socket.
  6. Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 6 단계, 이미지 3개 중 1개 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 6 단계, 이미지 3개 중 2개 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: 6 단계, 이미지 3개 중 3개
    • Locate the chip marked LS132 located at 6A.
    • Connect the Red and Black wires as shown in the second image on this step.
    • It is best to place a piece of electrical tape on the wires to help hold them in place.
  7. Apple Lisa MacWorks II PFG Instalation: 7 단계, 이미지 1개 중 1개
    • Replace the I/O Board back into Lisa's Card Cage.
    • Replace Lisa's Card Cage Back into the Lisa.
    • Replace the rear panel on the Lisa.
    • MacWorks + II (MW+II) floppy images can be found here.
    • The MW+II manual can be found here which includes detailed instructions how to instal thel MW+II software.
결론
  • MW+II supports Macintosh System Software up to Macintosh System 7.5.5.
  • Supports over 10MB of RAM (more than 4MB requires an XLerator.)
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
LisaGuide
회원 가입일: 12/30/18
1,833 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 793
