주요 콘텐츠로 건너뛰기
Apple Lisa SCSI Card Installation
필요한 것
  1. Apple Lisa SCSI Card Installation, Disassembly: 1 단계, 이미지 2개 중 1개 Apple Lisa SCSI Card Installation, Disassembly: 1 단계, 이미지 2개 중 2개
  2. Apple Lisa SCSI Card Installation, Installing the SCSI Card: 2 단계, 이미지 2개 중 1개 Apple Lisa SCSI Card Installation, Installing the SCSI Card: 2 단계, 이미지 2개 중 2개
    • Locate Lisa's expansion slots.
    • Locate expansion slot 3.
    • Pull the metal rod out from slot 3 and rotate 90º clockwise.
    • Slide the SCSI Card into expansion slot 3.
    • Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
    • The SCSI card includes 1 internal connector and 1 external connector.
    • The internal connector is used for connecting a hard disk.
    • If you intend to connect a hard disk then connect it now.
    • Pin 1 is marked.
    • The SCSI Card can also be cut to accommodate a Card Cage fan upon order request.
  3. Apple Lisa SCSI Card Installation, Reinstall Rear Panel: 4 단계, 이미지 1개 중 1개
    • Reinstall the Lisa's rear panel.
  4. Apple Lisa SCSI Card Installation, Using the SCSI Card: 5 단계, 이미지 1개 중 1개
    • The SCSI Card requires MacWorks Plus II.
    • To use devices connected to the SCSI card please refer to the device's manual for proper device installation.
    • This SCSI card was installed to use an Apple External SCSI CD-ROM Drive.
결론
작성자
1다른 기여자 명과 함께
LisaGuide
회원 가입일: 12/30/18
1,833 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 694
