주요 콘텐츠로 건너뛰기
Apple Magic Keyboard 2 A2450 Lower Case Replacement
필요한 것
  1. Apple Magic Keyboard 2 A2450 Lower Case Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 Apple Magic Keyboard 2 A2450 Lower Case Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 Apple Magic Keyboard 2 A2450 Lower Case Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
결론
Connor Bassolino
회원 가입일: 03/29/22
17,653 평판
안내서 76개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,738개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 304
