주요 콘텐츠로 건너뛰기
Apple Magic Keyboard 2 A2450 Motherboard Replacement
필요한 것
  1. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Apple Magic Keyboard 2 A2450 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Apple Magic Keyboard 2 A2450 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Apple Magic Keyboard 2 A2450 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Apple Magic Keyboard 2 A2450 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brayden Devenport
회원 가입일: 04/02/24
130 평판
안내서 1개를 작성함
IUPUI, Team 3-2, Harley Spring 2024 IUPUI, Team 3-2, Harley Spring 2024 회원
IUPUI-HARLEY-S24S3G2
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 27
전체 시간: 470
