주요 콘텐츠로 건너뛰기
Apple Pencil (2nd Generation) Tips Replacement
필요한 것
  1. Apple Pencil (2nd Generation) Tips Replacement, Preparation: 1 단계, 이미지 3개 중 1개 Apple Pencil (2nd Generation) Tips Replacement, Preparation: 1 단계, 이미지 3개 중 2개 Apple Pencil (2nd Generation) Tips Replacement, Preparation: 1 단계, 이미지 3개 중 3개
    • Grab your Apple Pencil Second Generation.
    • Make sure you have replacement tips. You can buy them from Apple or from 3rd party vendors on Amazon.
  2. Apple Pencil (2nd Generation) Tips Replacement, Unscrewing and Installing the tip: 2 단계, 이미지 1개 중 1개
    • To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
    • Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
tayola
회원 가입일: 07/21/22
9,868 평판
안내서 44개를 작성함
3가이드 댓글
Ich habe das Problem, daß der "Hals" der Kunststoffspitze im Pencil steckt. Ich bekomme ihn nicht heraus. Hat jemand eine Lösung?
Busso - 답글
Is there a guide to actually fix a broken tip for the 2nd gen?
We have staff who've had the tip break and the base of it remains lodged in the tip receptacle.
Adam Macks - 답글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 85
지난 30일: 496
전체 시간: 25,302
