소개
This guide will help you replace your Apple Pencil tip.
필요한 것
To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Ich habe das Problem, daß der "Hals" der Kunststoffspitze im Pencil steckt. Ich bekomme ihn nicht heraus. Hat jemand eine Lösung?
Hier ist eine perfekte Beschreibung: https://www.youtube.com/watch?v=9zyHaQT_...
