주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Apple Pencil 수리는 저희 서비스 설명서를 사용하십시오.
  1. Apple Pencil Teardown, Apple Pencil Teardown: 1 단계, 이미지 1/3 Apple Pencil Teardown, Apple Pencil Teardown: 1 단계, 이미지 2/3 Apple Pencil Teardown, Apple Pencil Teardown: 1 단계, 이미지 3/3
    • Apple's been tight-lipped on this pointer's finer points, but here's what we know for sure:
    • Bluetooth 4.1
    • Scans at twice the rate of finger inputs
    • Up to 12 hours of battery life
    • 175 mm (L) x 8.9 mm (D)
    • Lightning connector for charging
  2. Apple Pencil Teardown: 2 단계, 이미지 1/3 Apple Pencil Teardown: 2 단계, 이미지 2/3 Apple Pencil Teardown: 2 단계, 이미지 3/3
    • There's been a lot of talk about Pencil. Let's sketch out a couple quick comparisons to some other styling styluses.
    • First: the Microsoft Surface Pen (from a Surface Pro 4).
    • Second: The original "iPad Pencil" by 53. It works specifically with their Paper app, and has a lot of the same features as the new Apple Pencil.
    • Also, it's really easy to open up and get the battery out.
    • Double-also, it has an eraser.
  3. Apple Pencil Teardown: 3 단계, 이미지 1/3 Apple Pencil Teardown: 3 단계, 이미지 2/3 Apple Pencil Teardown: 3 단계, 이미지 3/3
    • Apple was nice enough to include a spare tip, as well as a Lightning-to-Lightning adapter (a last minute addition) to save users from having to precariously charge their Pencils directly from their iPads.
    • The Lightning Connector cap snaps into place with magnets, but we're expecting most of these will be lost by next month.
    • Popping the cap off reveals a brand new, never-before-seen model number: A1603. Welcome to the world, Pencil!
  4. Apple Pencil Teardown: 4 단계, 이미지 1/3 Apple Pencil Teardown: 4 단계, 이미지 2/3 Apple Pencil Teardown: 4 단계, 이미지 3/3
    • Taking a nosedive into the Pencil, we start at the nib, which comes off quietly with a few quick twists.
    • A peek inside reveals a tiny metal bit sunk deeply into the tip, presumably to get as close to the screen as possible.
    • This likely connects to one of the two emitters in the tip that allow the iPad Pro to determine the Pencil's angle and orientation relative to the display, and adjust the pen stroke accordingly.
    • The digitizer on an iPad Pro should be able to determine the distance from each emitter to the screen—and from that calculate the angle of the Pencil relative to the iPad.
  5. Apple Pencil Teardown: 5 단계, 이미지 1/3 Apple Pencil Teardown: 5 단계, 이미지 2/3 Apple Pencil Teardown: 5 단계, 이미지 3/3
    • We're eager to get a closer look at the eraser Lightning Connector, so we turn up the heat with our trusty iOpener.
    • Author's note: the fact that they bothered to call this the Pencil—and not the Pen/Stylus—and then failed to include an eraser is just absurd.
    • Even after a warm conversation with our iOpener, the Lightning Connector assembly still doesn't want to come completely out of its shell, but a quick tug frees it from the Pencil.
    • But at what cost... We definitely tore a flex cable...
    • Something tells us this isn't going to be one of those teardowns where everything goes back together at the end.
  6. Apple Pencil Teardown: 6 단계, 이미지 1/3 Apple Pencil Teardown: 6 단계, 이미지 2/3 Apple Pencil Teardown: 6 단계, 이미지 3/3
    • Having thoroughly dissected the top and bottom portions and finding no obvious point of entry, we throw caution to the wind and break out the big guns.
    • Cutting through the Bic Apple Pencil's plastic casing reveals an ink cartridge a metal casing.
    • And we haven't punctured the battery...yet! Looks like our Operation skills are finally paying off.
  7. Apple Pencil Teardown: 7 단계, 이미지 1/3 Apple Pencil Teardown: 7 단계, 이미지 2/3 Apple Pencil Teardown: 7 단계, 이미지 3/3
    • Whew—that was some work! Wiping up the plastic dust and pausing for a quick burrito break, we take a moment to appreciate the fruit of our efforts: Pencil sans case.
    • A quick glance along the inner metal cylinder reveals a tiny tri-point screw à la Apple Watch.
    • Luckily we've got the tools for this in our arsenal now. No files needed!
    • Below the tiny fastener, we spy some tiny contacts, which we assume are for Apple's internal testing.
  8. Apple Pencil Teardown: 8 단계, 이미지 1/3 Apple Pencil Teardown: 8 단계, 이미지 2/3 Apple Pencil Teardown: 8 단계, 이미지 3/3
    • After some more cutting and prying—and a brief conversation about laser cutters—we bust through a second (this time metal) layer.
    • We're rewarded with the antenna and battery assembly. No graphite at the core of this Pencil.
    • This tiny 3.82 V, 0.329 Wh lithium-ion battery holds just 5% of the charge of an iPhone 6s battery.
    • For the sake of scorekeeping: Microsoft's Surface Pen has a user-replaceable AAAA battery. These are usually rated anywhere from 0.4 to 0.9 Wh.
  9. Apple Pencil Teardown: 9 단계, 이미지 1/2 Apple Pencil Teardown: 9 단계, 이미지 2/2
    • With the metal casing off, we pop off the antenna, decked in the familiar Apple black and gold.
    • We also get a better look at that ribbon cable we sheared earlier... It runs between the Lightning connector and battery, with some battery charging ICs along the way (we assume).
    • We've caught sight of more chips at the other end, so we ditch the battery and move to the fun stuff—like the teeeny logic board!
    • This little board is folded in half to make the most of the minimal space. Clever!
  10. Apple Pencil Teardown: 10 단계, 이미지 1/2 Apple Pencil Teardown: 10 단계, 이미지 2/2
    • What is this—a logic board for ants? Not quite, but weighing in at a whopping 1.0 gram it's definitely the smallest we've ever seen. With the hard work out of the way, we pause to see what makes the Pencil so smart:
    • STMicroelectronics STML151UCY6 Ultra-low-power 32-bit RISC ARM-based Cortex-M3 MCU
    • STMicroelectronics STMLS05 5-channel PMOS load switches
    • STMicroelectronics STM32L052T8 32-Bit ARM Cortex-M0+ Microcontroller w/ 64 Kb flash
    • Maxim Integrated MAX11290 24-bit delta-sigma A/D converter (likely)
    • Cambridge Silicon Radio (Qualcomm) CSR1012A05 Bluetooth smart IC
    • Bosch Sensortec BMA282 accelerometer
    • Maxim Integrated MAX44284 high precision current-sense amplifier
  11. Apple Pencil Teardown: 11 단계, 이미지 1/3 Apple Pencil Teardown: 11 단계, 이미지 2/3 Apple Pencil Teardown: 11 단계, 이미지 3/3
    • We turn back to the metal casing to extract the pen nib and look for its sensor magic.
    • Peeling up one of the tiniest boards we've ever seen we find a set of three matching ticks. Three on the end of the pen assembly, and three on the tiny board.
    • If we had to hazard a guess, we'd say these helped sense pressure by measuring movement between these two parts.
    • Chances are this chip could tell us more about how this works...
    • It reads 8529043 343S00008-A1—likely a custom STMicroelectronics controller for the nib.
  12. Apple Pencil Teardown: 12 단계, 이미지 1/3 Apple Pencil Teardown: 12 단계, 이미지 2/3 Apple Pencil Teardown: 12 단계, 이미지 3/3
    • Further teardown of the tip seems impractical, but that's okay: we have eyes everywhere, thanks to some slick X-ray imaging from our pals at Creative Electron.
    • Get a load of that tiny spring-loaded tip, and the two emitters buried within the shaft.
    • Just for kicks, we also imaged the itty bitty folded logic board, and the Lightning Connector and cap.
    • Fortunately this was captured when the Pencil was still intact, so you can still see the connector neatly soldered to its little ribbon cable. It's a thing of beauty (at least until the day you need to repair something).
  13. Apple Pencil Teardown: 13 단계, 이미지 1/3 Apple Pencil Teardown: 13 단계, 이미지 2/3 Apple Pencil Teardown: 13 단계, 이미지 3/3
    • Apple Pencil Repairability 1 out of 10 (10 is easiest to repair):
    • The pen nib and cap can be replaced if worn out (or lost).
    • The pencil is clearly not meant to be opened or repaired; you can't get inside without destroying the device.
    • The layers of plastic and metal holding interior components are impossible to remove without shredding.
    • The battery, enough for a 12 hour run, is impossible to replace, giving the device a limited lifespan.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 50개
What vice did you use to hold the iPencil while you opened it? I need one.
Calion - 답글
I actually used our economy suction vise, it's pretty hefty and very stable :)
Andrew Optimus Goldheart -
Care to tear apart the female-to-female Lightning adapter? Interested to know the pinout!
Jake - 답글
I'm quite sure just a parallel connection.
Ryo Saeba -
Could we get a tear down of a Surface Pen? #3 maybe #4?
Eric Pellegrini - 답글
댓글 쓰기
조회 통계:
24 시간 전: 105
7일 전: 628
30일 전: 2,747
전체 시간: 396,300
