주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This repair will need:
A T8 Torx Screwdriver.
부품
지정된 부품이 없습니다.
  1. With the Generally Disassembly completed, you may proceed to floppy drive installation.
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Remove the plastic panel at the bottom of the display.
    • Remove the plastic panel at the bottom of the display.
  3. Reverse the computer to access the peripheral panel in the back.
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Manta(만타) 드라이버 키트
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta(만타) 드라이버 키트
  5. Reverse the computer to have the monitor and mousepad facing you.
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  6. Remove the three T8 Torx screws securing the floppy drive to the frame.
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  7. Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  8. Lift the defective floppy drive from the body of the computer.
    • Lift the defective floppy drive from the body of the computer.
  9. Replace the defective drive with a new drive.
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kevin Peters
회원 가입일: 2011년 04월 19일
114 평판
안내서 1개 작성함
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G66
4 회원들
안내서 3개 작성하였습니다
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 6
전체 시간: 2,213
