주요 콘텐츠로 건너뛰기
Apple Powerbook 520 Floppy Drive Replacement
필요한 것
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: 1 단계, 이미지 1/1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: 2 단계, 이미지 1/1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: 3 단계, 이미지 1/1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: 4 단계, 이미지 1/1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: 5 단계, 이미지 1/1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: 6 단계, 이미지 1/1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: 7 단계, 이미지 1/1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: 8 단계, 이미지 1/1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kevin Peters
회원 가입일: 04/19/11
130 평판
안내서 1개 작성함
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G66
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 2,712
