이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With the Generally Disassembly completed, you may proceed to floppy drive installation.
Reverse the computer to access the peripheral panel in the back.
Remove the two T8 Torx screws on either side of the bar code panel.
Reverse the computer to have the monitor and mousepad facing you.
Remove the plastic panel underneath the display.
Remove the three T8 Torx screws securing the floppy drive to the frame.
Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Replace the defective drive with a new drive.
Follow these instructions in reverse order to reassemble the device.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
