주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
In order to obtain access to the internal components you must first follow this step by step general disassembly guide. This will be a first stop in installing a new component that is enclosed by the outer shell.
부품
지정된 부품이 없습니다.
  1. Turn computer over. Remove battery expansion cover and battery.
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. With monitor hinge at the bottom, remove the two top center screws.
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Remove top left and top right screws.
    • Remove top left and top right screws.
  4. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  5. Remove middle left and middle right screws.
    • Remove middle left and middle right screws.
  6. Open computer kickstands.
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  7. Lift keyboard from bottom and take out of shell.
    • Lift keyboard from bottom and take out of shell.
  8. Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool. Removing both ribbon cables from the motherboard will leave the clamps like so. From here you can access the logic board, hard drive, and floppy drive.
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Mark McNeff
회원 가입일: 2011년 04월 20일
469 평판
안내서 2개 작성하였습니다
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - 답글
Thanks been trying to fix this for a long time
Luke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 23
전체 시간: 4,682
