소개
In order to obtain access to the internal components you must first follow this step by step general disassembly guide. This will be a first stop in installing a new component that is enclosed by the outer shell.
필요한 것
With monitor hinge at the bottom, remove the two top center screws.
Not necessary for RAM, hard drive, or CPU replacement.
The Screws are T8!
Remove top left and top right screws.
Open computer kickstands.
Remove screws underneath each kickstand.
Again not necessary for RAM, hard drive, or CPU replacement.
Philips PH00 screws
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
