주요 콘텐츠로 건너뛰기
Apple Powerbook 520/540 General Disassembly
필요한 것
  1. Apple Powerbook 520/540 General Disassembly, Case: 1 단계, 이미지 1/2 Apple Powerbook 520/540 General Disassembly, Case: 1 단계, 이미지 2/2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: 2 단계, 이미지 1/1
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - 답글
    The Screws are T8!
    Willy Kaiser - 답글
  3. Apple Powerbook 520/540 General Disassembly: 3 단계, 이미지 1/1
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - 답글
  4. Apple Powerbook 520/540 General Disassembly: 4 단계, 이미지 1/1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: 5 단계, 이미지 1/1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - 답글
  6. Apple Powerbook 520/540 General Disassembly: 6 단계, 이미지 1/1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: 7 단계, 이미지 1/3 Apple Powerbook 520/540 General Disassembly: 7 단계, 이미지 2/3 Apple Powerbook 520/540 General Disassembly: 7 단계, 이미지 3/3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Mark McNeff
회원 가입일: 04/20/11
497 평판
안내서 2개 작성하였습니다
댓글 2개
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - 답글
Thanks been trying to fix this for a long time
Luke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 48
전체 시간: 6,684
