주요 콘텐츠로 건너뛰기
Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Wineteer
회원 가입일: 04/13/11
154 평판
안내서 1개 작성함
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 회원
CPSU-GARNER-S11S25G30
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 26
전체 시간: 3,059
