주요 콘텐츠로 건너뛰기
Apple Powerbook 5300 Memory Replacement
필요한 것
  1. Apple Powerbook 5300 Memory Replacement, Battery: 1 단계, 이미지 1/1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: 2 단계, 이미지 1/1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Memory Replacement: 3 단계, 이미지 1/1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Memory Replacement, Memory: 4 단계, 이미지 1/1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
결론
Scott
회원 가입일: 04/26/11
155 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 회원
CPSU-GARNER-S11S25G30
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,354
