주요 콘텐츠로 건너뛰기
Apple Studio Display M2454 CCFL Inverter Replacement
필요한 것
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: 1 단계, 이미지 1/2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: 1 단계, 이미지 2/2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: 2 단계, 이미지 1/1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: 3 단계, 이미지 1/2 Apple Studio Display M2454 CCFL Inverter Replacement: 3 단계, 이미지 2/2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: 4 단계, 이미지 1/1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: 5 단계, 이미지 1/1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: 6 단계, 이미지 1/1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Dylan Perry
회원 가입일: 01/20/10
177 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 회원
CPSU-MANESS-W10S13G27
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 6,763
