주요 콘텐츠로 건너뛰기
Apple Studio Display M2454 LCD Main Board Replacement
필요한 것
  1. Apple Studio Display M2454 LCD Main Board Replacement, LCD Main Board: 1 단계, 이미지 1개 중 1개
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  2. Apple Studio Display M2454 LCD Main Board Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the three 2mm hex screws located on the back stand of the monitor.
    • These screws must be removed with the 2mm hex screwdriver in order for the back panel to be removed.
  3. Apple Studio Display M2454 LCD Main Board Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the clear back panel cover off.
    • Be sure to feed the cable through the back panel so no damage occurs.
  4. Apple Studio Display M2454 LCD Main Board Replacement: 4 단계, 이미지 1개 중 1개
    • Now remove the back panel under the clear cover.
    • Again, feed the cable through the panel so no damage occurs.
  5. Apple Studio Display M2454 LCD Main Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the phillips head screw holding the back panel spacer with the phillips head screwdriver.
  6. Apple Studio Display M2454 LCD Main Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two phillips head screws near the cable attachment with the phillips head screwdriver.
  7. Apple Studio Display M2454 LCD Main Board Replacement: 7 단계, 이미지 1개 중 1개
    • To remove the metal plate covering the circuitry you need to push the cover towards the base of the monitor.
    • If done correctly the tabs holding the plate should be detached and the plate will easily pop off.
  8. Apple Studio Display M2454 LCD Main Board Replacement: 8 단계, 이미지 1개 중 1개
    • Now that the circuitry is exposed the boards can be seen and replaced.
    • The LCD Main Board is the largest board in the center of the device with seven external connections.
  9. Apple Studio Display M2454 LCD Main Board Replacement: 9 단계, 이미지 1개 중 1개
    • Locate the four phillips head screws on the corners of the board.
    • Using the phillips head screwdriver, remove the four screws holding the board to the monitor.
  10. Apple Studio Display M2454 LCD Main Board Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the four braided connections simply by pushing the side of the connectors in and pull out.
  11. Apple Studio Display M2454 LCD Main Board Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the other two connectors by raising the tab on each either by hand or using a flat ended tool as shown.
    • Then gently pull away from the board to release tabs.
    • The tabs can easily break off, be extra careful.
  12. Apple Studio Display M2454 LCD Main Board Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the final black connector by pressing down on the back of the tab on the connector and then pull away from the board.
    • Be careful when holding onto the board while removing this connector or you risk pulling the board away too quickly and damaging the connector.
  13. Apple Studio Display M2454 LCD Main Board Replacement: 13 단계, 이미지 1개 중 1개
    • With all the connectors removed the board can be lifted away.
    • Now the new board can be attached by following the previous steps in reverse.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dylan Perry
회원 가입일: 01/20/10
177 평판
안내서 5개를 작성함
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 회원
CPSU-MANESS-W10S13G27
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 3,849
