이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The LCD main board is the backbone of the Apple Studio Display M2454. It accepts the information coming from the computer and transmits this data to the screen to form an image. The main board is also wired into the USB ports on the back of the monitor and other circuitry. There are many connections but replacing this board is relatively easy.
필요한 것
Locate the four hex head screws located on the corners of the back panel.
Remove the screws with a 2mm hex screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
