주요 콘텐츠로 건너뛰기
Apple Studio Display M7649 Inverter Replacement
필요한 것
  1. Apple Studio Display M7649 Inverter Replacement, Stand: 1 단계, 이미지 2개 중 1개 Apple Studio Display M7649 Inverter Replacement, Stand: 1 단계, 이미지 2개 중 2개
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Inverter Replacement, Panels: 2 단계, 이미지 1개 중 1개
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Inverter Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Inverter Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: 5 단계, 이미지 1개 중 1개
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 Inverter Replacement: 6 단계, 이미지 1개 중 1개
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 Inverter Replacement: 7 단계, 이미지 2개 중 1개 Apple Studio Display M7649 Inverter Replacement: 7 단계, 이미지 2개 중 2개
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 Inverter Replacement, Inverter: 8 단계, 이미지 1개 중 1개
    • Remove these three screws holding the board to the display
  9. Apple Studio Display M7649 Inverter Replacement: 9 단계, 이미지 1개 중 1개
    • Remove these five cables connection the inverter to the backlights and logic board.
    • Taking note where they connect to for reassembly
  10. Apple Studio Display M7649 Inverter Replacement: 10 단계, 이미지 1개 중 1개
    • Remove and replace the inverter
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Tsao
회원 가입일: 01/19/10
186 평판
안내서 5개를 작성함
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 회원
CPSU-MANESS-W10S3G20
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 7,393
