소개
Removing the metal Shield of the Apple display. This shield protects the components from electromagnetic interference.
필요한 것
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
다른 한 분이 해당 안내서를 완성하였습니다.
