주요 콘텐츠로 건너뛰기
Apple Studio Display M7649 Rear Panel Replacement
필요한 것
  1. Apple Studio Display M7649 Rear Panel Replacement, Stand: 1 단계, 이미지 1/2 Apple Studio Display M7649 Rear Panel Replacement, Stand: 1 단계, 이미지 2/2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Rear Panel Replacement, Panels: 2 단계, 이미지 1/1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Rear Panel Replacement: 3 단계, 이미지 1/1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Rear Panel Replacement: 4 단계, 이미지 1/1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Alan Truong
회원 가입일: 01/19/10
566 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 회원
CPSU-MANESS-W10S3G20
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 3,683
