주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Apple Studio Display M7649 수리는 저희 서비스 설명서를 사용하십시오.
  1. Apple Studio Display M7649 Teardown, Apple Studio Display M7649 Teardown: 1 단계, 이미지 1/2 Apple Studio Display M7649 Teardown, Apple Studio Display M7649 Teardown: 1 단계, 이미지 2/2
    • The Apple 17" ADC Studio Display
  2. Apple Studio Display M7649 Teardown: 2 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 2 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 2 단계, 이미지 3/3
    • Start by fliping the display so it is face down.
    • Remove these 3 hex screws on the swing arm of the display.
    • Then remove the swing arm, and the piece of plastic underneath it.
  3. Apple Studio Display M7649 Teardown: 3 단계, 이미지 1/2 Apple Studio Display M7649 Teardown: 3 단계, 이미지 2/2
    • The Swing Arm:
    • The Piece of plastic under the swing arm, you need to remove this(2nd Photo).
  4. Apple Studio Display M7649 Teardown: 4 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 4 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 4 단계, 이미지 3/3
    • To remove the back panel, remove these hex screws.
    • Then lift the panel from the top of the display.
  5. Apple Studio Display M7649 Teardown: 5 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 5 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 5 단계, 이미지 3/3
    • Removing the 2nd panel:
    • Grasp the bottom of the 2nd panel and lift it up, route the ADB cable through the hole.
    • This will reveal a shiney metal panel.
    • There may be tape here, remove it.
    • Remove this screw.
  6. Apple Studio Display M7649 Teardown: 6 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 6 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 6 단계, 이미지 3/3
    • Removing the metal shield:
    • After the tape and screw is removed, slide the panel towards you and lift it out.
    • Also, remove the clear USB port cover.
    • We now have full access to the electronics.
  7. Apple Studio Display M7649 Teardown: 7 단계, 이미지 1/1
    • To partially free the ADC cable, remove these 6 phillips screws, than remove the metal hinge and the cable elbow.
  8. Apple Studio Display M7649 Teardown: 8 단계, 이미지 1/1
    • Removing the USB Port Assembly:
    • Remove these 4 phillips screws, and this connector to free the port assembly.
  9. Apple Studio Display M7649 Teardown: 9 단계, 이미지 1/2 Apple Studio Display M7649 Teardown: 9 단계, 이미지 2/2
    • Removing the ADC Cable:
    • Remove these phillips screws.
    • Remove these 3 connectors CareFully!
    • The ADC cable should now be free from the rest of the monitor.
    • Remove this cable as well.
    • The ADC Cable, similar to DVI, provides power, signal, and USB to the display (2nd Photo).
  10. Apple Studio Display M7649 Teardown: 10 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 10 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 10 단계, 이미지 3/3
    • Removing the backlight inverter:
    • Remove these 4 connectors, it is important to remember their order!
    • Remove these 3 phillips screws.
  11. Apple Studio Display M7649 Teardown: 11 단계, 이미지 1/2 Apple Studio Display M7649 Teardown: 11 단계, 이미지 2/2
    • Removing the logic board:
    • Remove these two connectors.
    • This one too!
  12. Apple Studio Display M7649 Teardown: 12 단계, 이미지 1/2 Apple Studio Display M7649 Teardown: 12 단계, 이미지 2/2
    • Remove these 4 phillips screws.
    • This connector isn't used, it is left disconnected, I am assuming that it is to test the display for Apple.
    • Lift the logic board out if the case and set it aside.
  13. Apple Studio Display M7649 Teardown: 13 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 13 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 13 단계, 이미지 3/3
    • Removing the inner rim and button assembly:
    • Using a flathead screwdriver, or spudger, remove the 4 pieces of plastic around the black frame.
    • This will reveal numerous phillips screws.
    • Remove them all.
  14. Apple Studio Display M7649 Teardown: 14 단계, 이미지 1/2 Apple Studio Display M7649 Teardown: 14 단계, 이미지 2/2
    • Once all of the screws are removed, lift the rim out.
  15. Apple Studio Display M7649 Teardown: 15 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 15 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 15 단계, 이미지 3/3
    • Removing the LCD Panel
    • Remove all of these screws from the metal frame.
  16. Apple Studio Display M7649 Teardown: 16 단계, 이미지 1/1
    • And, all of these:
  17. Apple Studio Display M7649 Teardown: 17 단계, 이미지 1/3 Apple Studio Display M7649 Teardown: 17 단계, 이미지 2/3 Apple Studio Display M7649 Teardown: 17 단계, 이미지 3/3
    • Once you have removed all of the screws, remove the rear metal panel, watching the inverter cables of course!, this will provide acess to the LCD Panel
    • The Panel is manufactured by Samsung, and aparerntly, aren't easy to find, I Googled the model # and found 2 results.
    • Well, that's it for this teardown, good luck!
  18. Apple Studio Display M7649 Teardown: 18 단계, 이미지 1/1
    • My Window-Modded Studio Display
    • This is a neat thing to do to your display if you get bored, it doesn't affect function, but looks really cool!
Chris Green
회원 가입일: 10/11/09
36,978 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 2개
I've got to ask. Are my eyes deceiving me, or is there a NEXT cube in the background?
eweonardspock - 답글
No that,s a nextstation
Luke -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 52
전체 시간: 24,569
