주요 콘텐츠로 건너뛰기
Apple Studio Display M7649 USB Port Replacement
필요한 것
  1. Apple Studio Display M7649 USB Port Replacement, Stand: 1 단계, 이미지 1/2 Apple Studio Display M7649 USB Port Replacement, Stand: 1 단계, 이미지 2/2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 USB Port Replacement, Panels: 2 단계, 이미지 1/1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 USB Port Replacement: 3 단계, 이미지 1/1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 USB Port Replacement: 4 단계, 이미지 1/1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 USB Port Replacement, Metal EMI Shield: 5 단계, 이미지 1/1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 USB Port Replacement: 6 단계, 이미지 1/1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 USB Port Replacement: 7 단계, 이미지 1/2 Apple Studio Display M7649 USB Port Replacement: 7 단계, 이미지 2/2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 USB Port Replacement, USB Port: 8 단계, 이미지 1/1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Apple Studio Display M7649 USB Port Replacement: 9 단계, 이미지 1/1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Apple Studio Display M7649 USB Port Replacement: 10 단계, 이미지 1/1
    • Remove the USB port
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Tsao
회원 가입일: 01/19/10
186 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 회원
CPSU-MANESS-W10S3G20
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 3,158
