주요 콘텐츠로 건너뛰기
Apple TV 2nd Generation Bottom Cover Replacement
필요한 것
  1. Apple TV 2nd Generation Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    구매
    • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
  2. Apple TV 2nd Generation Bottom Cover Replacement: 2 단계, 이미지 1/1
    • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
결론
Areej Bashawiri
회원 가입일: 09/28/17
201 평판
안내서 2개 작성하였습니다
University of Maine, Team S1-G2, Diaz Fall 2017 University of Maine, Team S1-G2, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 1,117
