주요 콘텐츠로 건너뛰기
Apple TV 2nd Generation Power Supply Replacement
필요한 것
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: 1 단계, 이미지 1/2 Apple TV 2nd Generation Power Supply Replacement, Power Supply: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    구매
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: 2 단계, 이미지 1/3 Apple TV 2nd Generation Power Supply Replacement: 2 단계, 이미지 2/3 Apple TV 2nd Generation Power Supply Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    구매
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: 3 단계, 이미지 1/2 Apple TV 2nd Generation Power Supply Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: 4 단계, 이미지 1/2 Apple TV 2nd Generation Power Supply Replacement: 4 단계, 이미지 2/2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Deanna Rice
회원 가입일: 09/28/17
261 평판
안내서 2개 작성하였습니다
University of Maine, Team S1-G2, Diaz Fall 2017 University of Maine, Team S1-G2, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G2
4 회원들
안내서 4개 작성하였습니다
댓글 2개
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - 답글
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 1,753
