주요 콘텐츠로 건너뛰기
Apple TV 3rd Generation Logic Board Replacement
필요한 것
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: 1 단계, 이미지 1개 중 1개
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: 3 단계, 이미지 1개 중 1개
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: 4 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Logic Board Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the power supply connector from the logic board with a spudger.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vincent Monteil
회원 가입일: 07/06/13
7,023 평판
안내서 19개를 작성함
4가이드 댓글
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - 답글
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - 답글
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 37
전체 시간: 10,374
