필요한 것
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
다른 10명이 해당 안내서를 완성하였습니다.
댓글 4개
Where can I find a 3rd Generation Apple TV Logic Board?
Good question! Did you manage to find a replacement?
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mine too, where could I find a logic board replacement???
where so i find a new base to replace it with
sharpeEZz - 답글
