소개
For many reasons this part may become damaged or you may need to remove it to access the inside. This Guide demonstrates how to do so.
도구
부품
지정된 부품이 없습니다.
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
To reassemble the device, firmly press the cover into place until it clicks. The apple logo should have its bottom facing towards the ports.
다른 3명이 해당 안내서를 완성하였습니다.
