이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
For many reasons this part may become damaged or you may need to remove it to access the inside. This Guide demonstrates how to do so.
필요한 것
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
To reassemble the device, firmly press the cover into place until it clicks. The apple logo should have its bottom facing towards the ports.
다른 4명이 해당 안내서를 완성하였습니다.
