주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple TV 3rd Generation Status LED Replacement
필요한 것
  1. Apple TV 3rd Generation Status LED Replacement, Snap-on Base: 1 단계, 이미지 1개 중 1개
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Status LED Replacement: 2 단계, 이미지 1개 중 1개
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Status LED Replacement, Logic Board: 3 단계, 이미지 1개 중 1개
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Status LED Replacement: 4 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Status LED Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Status LED Replacement, Power Supply: 5 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Status LED Replacement, Power Supply: 5 단계, 이미지 2개 중 2개
    • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • Do not pull the wires to remove the power supply. The connector is fragile.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
  6. Apple TV 3rd Generation Status LED Replacement, Status LED: 6 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Status LED Replacement, Status LED: 6 단계, 이미지 2개 중 2개
    • The last remaining part in the Apple TV is the status LED. You can remove this part with your plastic spudger.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vincent Monteil
회원 가입일: 07/06/13
7,023 평판
안내서 19개를 작성함
1가이드 댓글
Step 2: “caring not to break….”. Thanks, great guide. David
David Apimerika - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 23
전체 시간: 3,314
