소개
This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
필요한 것
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 8개
Any idea on where I can purchase. new logic board?
Where do you buy the board…….
