주요 콘텐츠로 건너뛰기
Apple TV 4K Logic Board Replacement
필요한 것
  1. Apple TV 4K Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: 2 단계, 이미지 1/2 Apple TV 4K Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: 3 단계, 이미지 1/2 Apple TV 4K Logic Board Replacement: 3 단계, 이미지 2/2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: 4 단계, 이미지 1/1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: 5 단계, 이미지 1/3 Apple TV 4K Logic Board Replacement: 5 단계, 이미지 2/3 Apple TV 4K Logic Board Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Keenan Barber
회원 가입일: 10/04/18
1,159 평판
안내서 3개 작성하였습니다
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G3
4 회원들
안내서 15개 작성하였습니다
댓글 8개
Where does one get a new logic board??
MP94025 - 답글
Any idea on where I can purchase. new logic board?
tylerchumchal - 답글
Where do you buy the board…….
Andy Grichtmeier - 답글
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - 답글
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 118
전체 시간: 7,950
