소개
This guide will show you how to access the battery and charging port in your Apple TV 4K remote for replacement.
필요한 것
Heat iOpener according to manufacturer's instructions.
Place over the face of the remote to soften the adhesive under the glass.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 8개
I second this. It would be great if someone could link us on where to buy the battery/charger replacement.
_ Dubb -
You won’t be able to source the original battery as it is spot welded to the lightning port cable and mobo cable, and is one unit. However if you can solder I have successfully replaced two remote batteries for about $6-$8 a battery.
I’ve searched high and low for this battery as mine will not maintain a charge for more than a few hours. I found this one for a Huawei watch: https://www.batteryclub.org/Goods/ECN106... that appears to be the correct specs, but I’m not sure it can be connected.
That noted, a new remote is only $52 and this battery is $39.50 plus shipping! So for my money a new remote is a better option since we know it will work, and it’s just $12 or so more! Nuts!
