주요 콘텐츠로 건너뛰기
Apple TV 4K Remote Logic Board Replacement
필요한 것
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: 1 단계, 이미지 1/1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: 2 단계, 이미지 1/2 Apple TV 4K Remote Logic Board Replacement: 2 단계, 이미지 2/2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: 3 단계, 이미지 1/1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: 4 단계, 이미지 1/2 Apple TV 4K Remote Logic Board Replacement: 4 단계, 이미지 2/2
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: 5 단계, 이미지 1/1
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: 6 단계, 이미지 1/2 Apple TV 4K Remote Logic Board Replacement: 6 단계, 이미지 2/2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: 7 단계, 이미지 1/1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: 8 단계, 이미지 1/1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Keenan Barber
회원 가입일: 10/04/18
1,159 평판
안내서 3개 작성하였습니다
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G3
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 43
30일 전: 104
전체 시간: 4,321
