주요 콘텐츠로 건너뛰기
Apple Time Capsule Model A1254 Back Plate Replacement
필요한 것
  1. Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: 1 단계, 이미지 3개 중 1개 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: 1 단계, 이미지 3개 중 2개 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: 1 단계, 이미지 3개 중 3개
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Back Plate Replacement: 2 단계, 이미지 2개 중 1개 Apple Time Capsule Model A1254 Back Plate Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Back Plate Replacement: 3 단계, 이미지 2개 중 1개 Apple Time Capsule Model A1254 Back Plate Replacement: 3 단계, 이미지 2개 중 2개
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Keaton Frahmann
회원 가입일: 10/06/16
825 평판
안내서 2개를 작성함
Cal Poly, Team 4-2, Livingston Fall 2016 Cal Poly, Team 4-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G2
4 회원들
안내서 17개를 작성함
2가이드 댓글
I had to open to destroy the hard drive for security reasons. The rubber bottom was so old it just tore to bits. I used a Dremel Multi-Max with a flat scraper blade to remove it in the end.
steve - 답글
must I put back on the rubber bottom or can I leave it off for maximum airflow?
Strider - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 107
전체 시간: 7,357
