소개
The fan regulates air flow to the Time Capsule allowing the internal components to maintain optimal temperature. If the fan has failed, it is very easy to replace and needs very little tools.
필요한 것
Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
How do I get the rubber feet off the old fan and put them on the new fan?
