주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Apple Universal Dock Model A1256 수리는 저희 서비스 설명서를 사용하십시오.
  1. Apple Universal Dock Model A1256 Teardown, Apple Universal Dock Model A1256 Teardown: 1 단계, 이미지 1/1
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Apple Universal Dock Model A1256 Teardown: 2 단계, 이미지 1/1
    • Remove the top case from the bottom.
  3. Apple Universal Dock Model A1256 Teardown: 3 단계, 이미지 1/1
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  4. Apple Universal Dock Model A1256 Teardown: 4 단계, 이미지 1/2 Apple Universal Dock Model A1256 Teardown: 4 단계, 이미지 2/2
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  5. Apple Universal Dock Model A1256 Teardown: 5 단계, 이미지 1/2 Apple Universal Dock Model A1256 Teardown: 5 단계, 이미지 2/2
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
회원 가입일: 06/23/10
67 평판
안내서 1개 작성함
댓글 한 개
Can the actual dock insert (the section the iPod would clot on top of) be used in an Apple iPod HiFi repair? (see repair article Apple iPod Hi-Fi iPod Dock Inserts Replacement)
Harrison C - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 40
전체 시간: 24,644
