주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Apple Vision Pro 수리는 자사의 서비스 설명서를 사용하세요.
  1. Apple Vision Pro Chip ID, Logic board front: 1 단계, 이미지 2개 중 1개 Apple Vision Pro Chip ID, Logic board front: 1 단계, 이미지 2개 중 2개
    • Apple APL1109/339S01081E M2 octa-core applications processor & graphics processing unit
    • Micron MT62F1G64D8WT-031 XT:B 8 GB LPDDR5 SDRAM memory
    • Apple APL1W08/339S01186 R1 sensor coprocessor
    • Kioxia K5A4RC2097 256 GB NAND flash
    • Apple APL109C/343S00627 power management
    • Apple APL109D/343S00628 power management
    • Apple APL1004/343S00629 power management
  2. Apple Vision Pro Chip ID: 2 단계, 이미지 1개 중 1개
    • Apple 338S00521-B0 power management
    • Texas Instruments LMK1C1104 clock buffer
    • Analog Devices LT8652S 8.5 A / 18 V dual channel synchronous step-down converter
    • Texas Instruments TPS62125 300 mA buck converter
    • Texas Instruments TPS61045 adjustable boost converter
    • onsemi FPF2895C current limit switch
    • Texas Instruments TPS70936 150 mA / 3.6 V LDO regulator
  3. Apple Vision Pro Chip ID, Logic board front connectivity chips: 3 단계, 이미지 1개 중 1개
    • USI 339S01015 WiFi/Bluetooth module
  4. Apple Vision Pro Chip ID, Logic board back: 4 단계, 이미지 2개 중 1개 Apple Vision Pro Chip ID, Logic board back: 4 단계, 이미지 2개 중 2개
    • Analog Devices TMC5072 dual 2-phase stepper motor driver
    • Lattice Semiconductor ICE5LP4K iCE40 Ultra FPGA
    • Likely Cirrus Logic CS46L11 audio codec
    • Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer
    • Texas Instruments TMUX1575 quad SPDT analog switch
    • Texas Instruments TS5A23159 dual SPDT analog switch
    • Texas Instruments TPS62135 4 A step-down converter
  5. Apple Vision Pro Chip ID: 5 단계, 이미지 1개 중 1개
    • Texas Instruments TLV6703 comparator w/ integrated reference
  6. Apple Vision Pro Chip ID, Charging board front: 6 단계, 이미지 2개 중 1개 Apple Vision Pro Chip ID, Charging board front: 6 단계, 이미지 2개 중 2개
    • This charging board is positioned in the battery pack.
    • STMicroelectronics STM32L4A6VG Arm Cortex-M4 microcontroller
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Texas Instruments CD3217B13 USB type-C controller
    • Texas Instruments TPD4S311A USB type-C port protector
    • Texas Instruments TPS62180 6 A synchronous buck converter
    • Texas Instruments TPS62160 1 A step-down converter
  7. Apple Vision Pro Chip ID, Charging board front sensors: 7 단계, 이미지 1개 중 1개
    • Bosch Sensortec accelerometer
  8. Apple Vision Pro Chip ID, Charging board back: 8 단계, 이미지 2개 중 1개 Apple Vision Pro Chip ID, Charging board back: 8 단계, 이미지 2개 중 2개
    • Renesas ISL9238C buck-boost battery charger
    • Renesas RAA489800 bidirectional buck-boost voltage regulator
  9. Apple Vision Pro Chip ID, Charging board back sensors: 9 단계, 이미지 1개 중 1개
    • Texas Instruments TMP103A temperature sensor
    • Texas Instruments TMP103B temperature sensor
  10. Apple Vision Pro Chip ID, Right speaker board: 10 단계, 이미지 2개 중 1개 Apple Vision Pro Chip ID, Right speaker board: 10 단계, 이미지 2개 중 2개
    • Texas Instruments SN02776B0A audio amplifier
7가이드 댓글
No ID of the sensor chips?
Quantum of solace - 답글
What do you think the Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer is for? What do you think the long module is at the bottom left of the main board?
Daniel De Sousa - 답글
What IC's control all the LEDs, cameras, etc? Are these in a module somewhere?
Sean Davis - 답글
I'm also waiting for ID of the sensor chips/modules. Are you going to update this site/article with more?
Fyo - 답글
Where’s four imu chip
nihao276720747 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 39
지난 30일: 206
전체 시간: 24,785
