주요 콘텐츠로 건너뛰기
Apple Watch Adhesive Replacement
필요한 것
  1. Apple Watch Adhesive Replacement, Adhesive: 1 단계, 이미지 1/2 Apple Watch Adhesive Replacement, Adhesive: 1 단계, 이미지 2/2
    • Use a plastic opening tool to scrape adhesive off the back of the screen.
  2. Apple Watch Adhesive Replacement: 2 단계, 이미지 1/2 Apple Watch Adhesive Replacement: 2 단계, 이미지 2/2
    • You may be able to peel up the adhesive with tweezers.
    • Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
  3. Apple Watch Adhesive Replacement: 3 단계, 이미지 1/2 Apple Watch Adhesive Replacement: 3 단계, 이미지 2/2
    • Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Be sure to get both the double-sided adhesive and the brown backing paper.
    • If you're having trouble navigating the double-sided adhesive, check out this video.
    • Be very careful not to fold, bend, or stretch the adhesive tape, as this will make it too thick to seal the screen without a ridge between the screen and the case.
  4. Apple Watch Adhesive Replacement: 4 단계, 이미지 1/3 Apple Watch Adhesive Replacement: 4 단계, 이미지 2/3 Apple Watch Adhesive Replacement: 4 단계, 이미지 3/3
    • Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests.
    • Start in a corner with the tape as close to the corner wall as possible.
    • Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
  5. Apple Watch Adhesive Replacement: 5 단계, 이미지 1/2 Apple Watch Adhesive Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
    • Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
  6. Apple Watch Adhesive Replacement: 6 단계, 이미지 1/3 Apple Watch Adhesive Replacement: 6 단계, 이미지 2/3 Apple Watch Adhesive Replacement: 6 단계, 이미지 3/3
    • To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down.
    • Snap the upper bracket in place.
  7. Apple Watch Adhesive Replacement: 7 단계, 이미지 1/3 Apple Watch Adhesive Replacement: 7 단계, 이미지 2/3 Apple Watch Adhesive Replacement: 7 단계, 이미지 3/3
    • Line the battery connector up with its mate on the cable inside the watch body.
    • Use tweezers to press the two connectors together.
  8. Apple Watch Adhesive Replacement: 8 단계, 이미지 1/3 Apple Watch Adhesive Replacement: 8 단계, 이미지 2/3 Apple Watch Adhesive Replacement: 8 단계, 이미지 3/3
    • If your replacement battery came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive.
    • Rotate the battery down into its slot, and press it into position.
    • Press the battery down against the S1 to re-adhere it in place.
    • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
  9. Apple Watch Adhesive Replacement: 9 단계, 이미지 1/1
    • Use tweezers to peel off the adhesive backing strip.
    • Peel the backing strip up halfway, then snip it with scissors so you can peel the rest off without it snagging on the display.
  10. Apple Watch Adhesive Replacement: 10 단계, 이미지 1/3 Apple Watch Adhesive Replacement: 10 단계, 이미지 2/3 Apple Watch Adhesive Replacement: 10 단계, 이미지 3/3
    • Move the screen back to the right, folding the display data and digitizer cables neatly.
    • Center the screen over the case and press it down firmly onto the adhesive.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
결승점
다른 227명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,807 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 46개
Where can I find the new screen.
Crissel Largo - 답글
THERE WOULD BE A PROBLEM WITH THE I.C. rewriting aiu moment of the change of LCD.?
wallace@freesurf.ch
vallottonge - 답글
How long before the adhesive strips will be back in stock? I've been waiting months now and still no update :)
Annie Booth - 답글
me too when can we expect it?
Luis Deluna -
댓글 쓰기
조회 통계:
24 시간 전: 51
7일 전: 365
30일 전: 1,607
전체 시간: 328,241
