주요 콘텐츠로 건너뛰기
Apple Watch Series 3 Adhesive Replacement
필요한 것
  1. Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: 1 단계, 이미지 2개 중 1개 Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • Apply a little bit of isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers on top of the force touch gasket.
    • To remove the adhesive on the side where the display cables are running, fold down the display and carefully pull it away from the frame so there's enough space.
  2. Apple Watch Series 3 Adhesive Replacement, Cleaning the display: 2 단계, 이미지 2개 중 1개 Apple Watch Series 3 Adhesive Replacement, Cleaning the display: 2 단계, 이미지 2개 중 2개
    • Flip the Apple Watch upside down so the display lays flat while lifting up the case.
    • Remove the leftovers on the back of the display.
  3. Apple Watch Series 3 Adhesive Replacement, Applying the new adhesive: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to carefully remove replacement adhesive with the blue protective film from the backing paper.
  4. Apple Watch Series 3 Adhesive Replacement: 4 단계, 이미지 2개 중 1개 Apple Watch Series 3 Adhesive Replacement: 4 단계, 이미지 2개 중 2개
    • Hold the replacement adhesive diagonally to thread it over the display.
    • Slightly tilt the display forward so you can align the adhesive with the frame.
    • Position the replacement adhesive on top of the force touch gasket and use the pointed end of a spudger to move and press it into place.
  5. Apple Watch Series 3 Adhesive Replacement: 5 단계, 이미지 1개 중 1개
    • Reconnect the battery as seen in the replacement guide you came from.
    • Remove the protective film from the adhesive.
  6. Apple Watch Series 3 Adhesive Replacement: 6 단계, 이미지 1개 중 1개
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive you can use an iOpener to warm up the display. Then apply some pressure for a few hours (placing it under one or two heavy books overnight might be a way).
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
결승점
다른 32명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,190 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
10가이드 댓글
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
Ryan Hoover - 답글
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - 답글
Yes mine was also larger than the adhesive seal that is advertised here.
Nicholas Goldsworthy - 답글
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - 답글
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
Vangelis Angelakis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 60
지난 30일: 290
전체 시간: 30,945
