주요 콘텐츠로 건너뛰기
Apple Wireless Keyboard Logic Board Replacement
필요한 것
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: 1 단계, 이미지 2개 중 1개 Apple Wireless Keyboard Logic Board Replacement, Logic Board: 1 단계, 이미지 2개 중 2개
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: 3 단계, 이미지 3개 중 1개 Apple Wireless Keyboard Logic Board Replacement: 3 단계, 이미지 3개 중 2개 Apple Wireless Keyboard Logic Board Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the logic board from the placement
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nicola
회원 가입일: 11/14/13
638 평판
안내서 1개를 작성함
9가이드 댓글
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - 답글
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - 답글
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - 답글
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - 답글
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 93
전체 시간: 50,067
