주요 콘텐츠로 건너뛰기
Apple XServe Raid Battery Replacement
필요한 것
  1. Apple XServe Raid Battery Replacement, Raid Battery: 1 단계, 이미지 2개 중 1개 Apple XServe Raid Battery Replacement, Raid Battery: 1 단계, 이미지 2개 중 2개
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: 4 단계, 이미지 3개 중 1개 Apple XServe Raid Battery Replacement: 4 단계, 이미지 3개 중 2개 Apple XServe Raid Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: 6 단계, 이미지 2개 중 1개 Apple XServe Raid Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the raid card battery out of the chassis.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cody West
회원 가입일: 10/20/20
234 평판
안내서 1개를 작성함
Texas Tech, Team S14-G2, Cowan Fall 2020 Texas Tech, Team S14-G2, Cowan Fall 2020 회원
TTU-COWAN-F20S14G2
1 회원
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 865
