주요 콘텐츠로 건너뛰기
Apple iPod Hi-Fi Grille Replacement
필요한 것
  1. Apple iPod Hi-Fi Grille Replacement, Grille: 1 단계, 이미지 1개 중 1개
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: 2 단계, 이미지 1개 중 1개
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Timothy Scheuermann
회원 가입일: 04/18/18
710 평판
안내서 3개를 작성함
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G1
5 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 21
전체 시간: 1,844
