주요 콘텐츠로 건너뛰기
Apple iSight Webcam Camera Replacement
필요한 것
  1. Apple iSight Webcam Camera Replacement, External Body Frame: 1 단계, 이미지 1개 중 1개
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Camera Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Camera Replacement: 3 단계, 이미지 2개 중 1개 Apple iSight Webcam Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Camera Replacement, Camera: 4 단계, 이미지 1개 중 1개
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Camera Replacement: 5 단계, 이미지 2개 중 1개 Apple iSight Webcam Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Camera Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Camera Replacement: 8 단계, 이미지 2개 중 1개 Apple iSight Webcam Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull out the ribbon cables at the base of the circuit board. The camera module and lens cap are connected to the board via two busses.
    • Make sure that all pins are loose before pulling them out or you could risk bending the pins or breaking the connector.
  9. Apple iSight Webcam Camera Replacement: 9 단계, 이미지 2개 중 1개 Apple iSight Webcam Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the three PH000 3.55mm screws that connect the end cap that holds the privacy shutter to the rest of the camera enclosure. Once the screw are removed, you can pull them apart.
  10. Apple iSight Webcam Camera Replacement: 10 단계, 이미지 2개 중 1개 Apple iSight Webcam Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Unscrew the three PH000 3.55mm screws from the connecting plate and the camera enclosure. Pull apart when all screws are removed.
  11. Apple iSight Webcam Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew the three PH000 3.55mm screws securing the Camera module circuit board and lens enclosure.
  12. Apple iSight Webcam Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the pin tab from the base of the circuit board to separate the camera module and the lens enclosure.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kaleb McArdle
회원 가입일: 03/21/18
199 평판
안내서 1개를 작성함
IUPUI, Team S5-G1, Baechle Spring 2018 IUPUI, Team S5-G1, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G1
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 52
전체 시간: 3,790
